Off-grid Inverter Comparison
Modern Off-grid inverters can be used to build either hybrid (grid-interactive) or off-grid solar systems to charge batteries using solar or backup AC power sources such as a generator. Off-grid inverters, also known as multi-mode inverters or inverter-chargers, supply pure sign-wave AC power and can be used to build stand-alone power systems that can be either AC-coupled with solar inverters or DC-coupled with MPPT solar charge controllers. Learn more about AC and DC-coupled systems here.
See our other inverter and battery comparison charts:
Off-grid Inverter Comparison Chart 2024
Please provide professional feedback here. Let us know of any new products, updates, or corrections.
Inverter Features explained:
Load Shifting = Enabling a controlled load/s to be turned on during peak solar generation periods
Peak Shaving = Also called peak lopping, is the ability to reduce peak demand from the grid
Batt sense = Battery sense input to take into account cable voltage drop and optimise battery charging
Batt mid sense = Battery mid string sensor to detect cell voltage imbalance (Gel and AGM - Lead Acid)
Generator support = Ability to automatically operate a generator based on specific load/battery parameters.
Off-Grid Load Calculator
Try our online interactive off-grid load calculator to quickly estimate the average daily demand (kWh), surge loads, and maximum demand in order to design reliable, high-performance off-grid power systems.
