Home > Solar Installers > New South Wales > Inner West Sydney > Marrickville
Solar Installers Marrickville NSW
Some top ranking installers on the web near Marrickville are:
  • Australian Solar Designs | Alexandria NSW
  • Aussie Hybrid Solar | Silverwater NSW
GET A SOLAR QUOTE FROM A CLEAN ENERGY REVIEWS INSTALL PARTNER
Already got a solar quote or two? Get them reviewed on our community forum: Solar Quote Reviews.
Optimal daily Solar Generation in Marrickville | kWh per kW installed
A solar panel system in Marrickville, New South Wales which is installed with good access to the sun, can get around 4.25 kWh of solar energy per kW installed on average per day throughout the year.
The optimal panel angle in Marrickville for year round solar production is 34° from the horizontal, and facing due North (0° azimuth). This allows for the most total production throughout the year. However, depending on when you use the most electricity, you may want to consider optimising your installation for different times in the year.
Summer optimised production - 19° pitch* | kWh per kW installed
Winter optimised production - 49° pitch* | kWh per kW installed
Bear in mind that roofs typically have a pitch of between 15 - 30°, and it usually makes sense if you are installing on a house, to simply lie the panels flat on the roof without changing the angle. This is due to cost, fixing and aesthetics. Installs look nicer when they are flat against the roof, they are more secure, and there is extra costs involved in changing the angle, both in parts and labour.
* This data is purely theoretical, based on solar irradiance and a 12% derating, every installation is different and should expect different outputs.
Cost of Solar in Marrickville
If you have a quote for a solar installation in the Inner West, visit our solar forum and you can have your quote reviewed by our team and community.
Examples of some pricing that we have seen for quotes near Marrickville:
  • Panels: 10.56kW, 32 x 330W QCELLS | Inverter: SMA TRIPOWER 10kW | Price: $10800 net
  • Panels: 9.3 kW, 30 x 310W Trina Honey M Plus | Inverter: Fronius Primo 8.2kW | Price: AUD$12100 gross ($1.51 per W - based on inverter output). Minus $5000 federal STC rebate = $7100 net
    • Option with LG Neon 2 panels = $11000 net ($2 per W gross)
  • Panels: 8.64 kW, 27 x 320W REC N | Inverter: SolarEdge HD 8kW | Price: AUD$15500 gross ($1.94 per W - based on inverter output). Minus $5000 federal STC rebate = $10500 net
    • Includes SolarEdge optimisers and Smartmeter
Solar Rebates
Most of New South Wales is in zone 3 for the federal STC rebate scheme. This means that for a 5kW system, in 2020 you are eligible for 76 certificates, which at the current price of around $35, you will receive a very handy $2660 off the upfront cost of your system.
Latest solar product reviews and information
