Photonik - Solar Panel Placement Design Tool
Free, easy-to-use solar system design tool
At Photonik, we believe in making the easiest-to-use solar design tools. It’s all part of our mission to make solar power accessible to everyone. In fact, we made our panel placement so easy to use that it is also accessible to consumers. Use our panel placement tool to determine how many panels will fit on your roof.
Consumer panel placement tool
INSTALLER panel placement tool
How to use the Photonik Panel Placement tool
Important: This is a super easy-to-use tool, but you have to tell the tool which way you want your panels to face.
To do this, you need to follow these simple steps:
  1. Draw the gutter line of your roof first, that is the lowest point of your roof and the direction toward which your panels should face. The first line you draw is perpendicular to where your solar panels will face.
  2. Make sure the yellow arrow is pointing in the direction your panels will face. The arrow will need to face South for south-facing roofs in the Northern Hemisphere. And for North-facing roofs in the Southern Hemisphere, the arrow must face North.
  3. Click on the corners of the roof area where you want to place panels.
  4. Press Enter to finish selecting the area
Watch this quick intro video
About the Photonik Solar Design Tool
Photonik is a solar design software that helps solar installers and contractors design, quote, and install solar PV systems. It is a cloud-based software that is easy to use and can be accessed from anywhere. Photonik offers a variety of features that make it a powerful tool for solar design, including:
Photonik features and highlights
  • Panel placement tool: Photonik helps you to optimise the layout of your solar system on your roof, which can help you to maximise your energy production.
  • Module and Inverter Selection: Photonik provides a library of modules and inverters for you to choose from, allowing you to select the best options for your project.
  • System costing: Photonik automatically calculates the cost of your solar system, which you can edit as required.
  • Proposal generation: Photonik can generate professional-looking proposals for your solar projects so you can easily communicate the benefits of solar to your customers.
Photonik is a powerful tool that can help you design, quote, and install solar PV systems more efficiently and effectively. If you are a solar installer or contractor, Photonik is a valuable resource that can help you grow your business.
Benefits of using the Photonik solar design tool
  • Simple to use: Photonik is designed to be easy to use, even for those with no prior experience in solar design.
  • Powerful: Photonik offers a wide range of features, making it a powerful tool for solar design.
  • Free: Photonik is free to use, and you can try it without signing up.
If you are looking for a solar design tool that is easy to use, powerful, and free, then Photonik is the perfect solution for you.
